KYB Shocks
Hi guys & gals,
Just about to have KYB AGX shocks fitted to my zed along with
Eibach springs, adjustable upper link arms, adjustable tension rods and adjustable anti roll bar link ends. What have you found to be the best settings to have the shocks on for general use.
cheers
bubbles
Hi guys & gals,
cheers
bubbles
most do 2 on the back 2 on the front,but im changing mine to 3 on the back for a firm rear over years the hicas systym isnt at best so needs a firmer ride at the rear HTH
Best bet is to play with it yourself see which setting you prefer
front 2
rear 2
Cheers Greg, also depends on how much BHP your pushing out i suppose,and ill be chipping it soon as well
bubbles
front 2
rear 2
FIRM REAR ??????????
PLAY WITH IT YOURSELF ??????????
have i read this wrong or what
no you havnt :D
for everyday use i set mine to 1 on the front and 1 on the back, because dont forget that the shocks are gas and about 20% uprated over the standard shock on the minimum settings, on track days i have 3F/6B and that seems good. I think you will be supprised at the diffrence they make just on min settings.
