Yay or Nah on these gauges?
As some of you have read, I've knackered my temp gauge.... I needed this excuse to buy some after market ones!
http://www.demon-tweeks.co.uk/catalogue/product_detail.asp?PCODE=TRIP134&GRP=RP073&PGRP=R008&CLS=ROAD&code=TRIP110&from=search
I found these on Demon-tweeks. I'm after some not so expensive ones, preferably with a blue backlight to match the rest of my interior. I know these arent a fancy expensive brand, thats not what I'm looking for at the mo... So what do you reckon??? Any good or are there others to consider?
Andrew
they look good...
with modern day technology most of the cheaper brands perform just as good (sometimes better )as the "labled brands" im well up for saving a bit of cash so imo i personally would consider these dials.
I have had these for about 2 years now. Very good. Especially that you get the boost and oil presure in PSI and the temperature in ºC and not ºF
i think there are 2 or 3 brands out there that use the same or similar gauge but put a different label on the front TBH. I have a Fast & Furious boost gauge (yes yes i know) but it works ok (although ive got nothing to calibrate against) and it changes colour ( :hyper: ) . looks exactly the same as the one pictured but says F&F instead.
Hello mate,
By the sounds of it you did the same as I did and knackered the temp guage :headvswal I went out and bought the PRO temp guage and could not get a good reading with it, I was advised to stay away from the electrical guage and go for a mechancal water gauge, so i took my one back and got the auto meter mechanical one and spot on it is i might say, and comes with a pale silver face and the numbers light up blue. if you need these then i will send you a link as they are so cheap and work perfect plus i got the water temp and also boost guage for about 35-40 all in BARGAIN. :hyper:
Ant
