Ok well basically, my luck is always sh1t to start off wid. I found a plastic bag about a week ago in my engine where the fan is around the bit that makes it spin, tangled up. I was wondering how did that get there? So i took it off etc... Same thing happened yesterday, i cud smell sumthing burning, opened it n found another plastic bag in the same place! Took it off wot not. I was driving later n the engine felt rough, as if sumthing was choking it a bit so it wudnt run as gud. N sum funny burning smell. As i got home parked it up n everything. This morning i thought i wud investigate the problem, i topped up my water level, dun a check on the engine n everything. Now i turned the car on n i see smoke cuming from one of the sparkplug areas, the top right area, next thing i see is flames, so i ran like hell inside to get sum water n put it out. I mean wot the hell started the fire, the sparkplug? How do i fix this problem?
shoot the fooker whoes putting plastic bagsin yer engine for a start.
there are fuel lines that run about there, you may have a leak, only prob now with the fire damage youl not be finding it. my advice is replace all the lines and hoses, then check it carefully with the engine going to see if you can smell anything
it could possibly be the coil pack, if there is a faulty ptu that could cause one or more of the coil packs to burn. Get you PTU checked and all your coil packs ASAP.
I got told the reason why bags got into my engine was coz the bottom cover is missing. N my car will start to burn even wid jus the ignition on. I got told its mos probably the fuel line kit or the electrics?
K found out wot it woz, a coil thingy. Any1 know how much these go for?
Phone ryan @ z-tech on 07968166640
im sure he can sort you one and post it :)
cheers greg
you could always stop typing phone text style too ! ;)
Y?...u h8 it?....r u 4 real?....nowt bad wit dat m8 n therefore doesn't tend to go on and on and on and on carrying over into several pages of shakespearien verse using valuable web space.:D :nelson:
Which is why i have a siggy to fill up the space and post whore as much as poss... :rofl: :slap: :nono:
Im only jesting scoops....Just bored so thought id post up some meaningless gargle... :dance: :mac1:
What a twat I am :smash:
Coil thing cost me 35 quid, cars running much better, i think that when the fire was there it musta burnt sumthing else as the overheating symbol cums on a bit now n then n a bit of smoke from the same area? God sumtimes dont u jus h8 cars.
