Boost jets
As my controller is now on the way to the menders i was thinking of putting boost jets (mig tips) in.
Can someone tell me which ones to use that will give me around 13/14 PSI?????
Do i still disconnect the stock solenoids when i put the jets in oh yes and do i put them in the lines feeding the underneath of the big hoses going into the plenum?????
hi Alex, i can only help you with one of your questions: 1mm jets will give you 12/13-ish, 0.8's will give you 14/15 (with the possibility of spiking higher :eek: )
