- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys
Guess What, my ZX TT has been going fine for about 3 weeks, and as soon as we hit May and Jap fest is soon, it starts playing up!
Here are the simptoms which I really need to get sorted ASAP. I havnt done a ECU cose check, as one, I dont know how too, and secondly at the moment untill the end of the week I have no internet access at home!
I took the car out the other day, going well, let it warm up before booting it etc. Took it down a long straight and it didnt seem that quick? Ok upto 60ish, but a bit lame around 100, (my vectra 175bhp Turbo would have left it for dust)!!!
I then noticed it was getting very hot! The needle was on the H!!!!
As I sl;owed down to around 50, the temp guage slowly dropped to half way. Then when I went to change down to 2nd as I approached the roundabout, the engine stalled! Restarted fine and drove normally. However every time I hit the throttle and give it a bit of boost, the temp goes up, almost as quick as the speedo!! This time over the H!!! One other symptom, it that the heater in the car will not blow hot air, just cool/warmish?
I also noticed that when ever I accelerate, when the turbo spools up it sounds like someone is playing a flute or recorder under my bonnet? However this is a new thing that only happened the last time I took it out. I thought it may be a stone in the intercooloer, but wouldnt have thought it would make this noise?
Yesterday I let the car run on the engine for a while, for around 15mins the temp stayed in the middle range, the fan cut in and out a bit, but still no heating? Then the revs started to go up and down, like it was going to stall?
After a further 5mins I looked and the the temp had rocketed and the electric fan was on constantly. And this was with the bonnet up. I switched off to notice the rad cap bubbling!!
The car has plenty of water, are there any water/air bleed screws for the heating/cooling system? Air lock?
Hope you can help guys!
Karl
By the way, this is an manual Twin Turbo.
