door glass snapped from guide stud
made the mistake of raising the drivers door glass while the door was open and then got out to close it. The door glass had gone up too far and the glass clattered against the T top edge and promptly snapped off the stud that rides the guide rail. Now I have a floppy window.
Is there a fix anyone or is it a special part from Nissan?
So nobody else ever broke the guide stud on the driver window then?
Sorry to hear about this, Not sure how you fix this, but something not right for this to happen. The window should'nt go up far enough to cause any damage.
You'll need to find out why this happened before repairing, or it could happen again.
Yeh I agree the new window should be adjusted to stop lower, mines ok when I do this, as far as the guide stud try a breaker there's loads of doors around someone will sort you one out I'm sure.
hi mate can you send me a pic of the part you need as i might have it?? i striped my drivers door down last year and got lots of parts still if i have it just pay the postage !!!!!
the@bookpeople.fsnet.co.uk jack 07879680606
Thanks lads. The part that broke is the metal stud through the glass. It broke off almost flush with the inside surface of the glass so the glass is fine. The dome head is still in the glass but I guess this will push out with a bit of care.
So Jack, if you ve got one of those I'd be most appreciative.
The window is just a bit wobbly now and you have to be really carefull closing it and the door.
Lol! Thats a suprise... stud broke, glass ok! !
You wanna buy a few lotto tickets!
