protoj · 15 hours ago 15 hr
Ive got these tiny little yellow spots (on my car) which were there when i bought the car off the previous owner a year ago, i have tried t-cut but it didnt work, anyone know a good product for getting rid of these sorts of things without getting back to bare metal :-)
Rob
