Aerial replacement !!
very easy to replace yourself i did mine few weeks ago you get one cheap,and it will take you half hour to get the old one out and new one in. :hyper:
mine got attacked too mate by a car wash !! get a secondhand one from someone breaking mate on here or andy z in traders section does spare parts bud.
Hi had my areial snapped !!
What the sp on a replacement, etc
Cheers Martin
hi martin removal is fairly simple remove interior trim next to where aerial is situated!
remove electrical connector
remove i think 2 nuts
then reach down and theres a vaccuem pipe with grommet pull upwards so its out of hole in boot
go outside and remove cap that surrounds aerial
then its a case of wiggling the old aerial unit out 20mins tops,re-fitting is same as removal,only fiddly bit is getting pipe back in with grommet
cheers greg
Thanks for your replies & PMs, & instructions Greg, got a 2nd hand one for £15 inc postage,
Cheers Martin
