protoj · Tuesday at 18:48 2 days
1994 Galant manual 2.5 V6 4WD/4WS going cheap for £1495 if anyone wants a winter Q car.High miles so what.Long test&t.Park it anywhere. Why wreck that Z. And still have fun, in this ulra rare UK car.
