howdy
in my jap spec z there is an alarm sensor marked up as keyless door lock in the drivers door, to which i havent the key fob. thing is the central locking doesnt work on the key.
i can hear the relay click in the drivers door but the is no power going to the passenger door (checked with a multimeter while turning key in drivers door lock) the fuse is ok as the internal light still works..
qusetion is where in the system could be the problem as it seems the passanger door isnt getting power to the lock? is there any inline fuses or other connector i should be searching for (tried to do a search on faq's but no luck on this problem)
any help would be very much appreciated
:confused:
the alarm perhaps bypasses the factory relay? the switch on the key barrell maybe still switches the factory relay, but the supply for the passanger door might come from the alarm circuit, bypassing the factory set up completely?
oooh poo!
cheers fraser i wanna get the central locking working but the cabling looks abit complicated to me. sounds like i have to get out there with the multimeter again and try and find a power feed for the passanger door
anybody know the colour code for the wires for the central locking from the drivers door??
oooh poo!
This is the same problem I have at the moment, my passenger side's never worked since I've had the car.
You can find the wiring diagram here . I wish you luck with it, let us know how you get on.
