protoj ·
Logged onto the Driven web site to pen a few words about last nights 'affordable' supercar, the NSX.
I got a little sidelined, there's a write up on the 350Z on the site so I guess it might be on our screens soon - hopefully
All under £24K
www.4car.co.uk
Tim
