Cracks inside the rear lenses
Hi Guys
Have a look at these photos. I dont remember seeing them last time i washed the car which was about 4 weeks ago. The cracks havent broken the surface so they are definately within the lense.
Im concerned what might have caused it as the other side is starting to do the same :confused:
Hi Guys.....
Old age, heat, stress??? But either way all you can do is replace them...... I beleive the technical term for them, is they are Fooked!!! (or very soon will be)
did you say you had your zx in storage a good while??
id say its the change in temp' or some condensation got inside
and heat from your lights has cracked them, as above not a lot you can do now m8
yes the Z has been in storage for a while and i do have evidence of condensation in the fog/reversing lights. guess its a good a reason to go 99'spec even tho it is expensive.
Cheers guys, i was just worried it was a sign of something alot worse.
