2 Quick questions! need help!
Ok, just got my car back from the car painters (pics soon!)
1) notice there is a 'gurgling' sound coming from the door area on both passenger and drivers side, only at idle. Suspect AIV valves, am I right?
So what do I do, remove them? drill a hole? Can a hole be drilled while everything is still in place on the car? Is there one on each side of the car? Also, why would it be fine a week ago, and bad now only a week after the car painters had it?
2) I pulled apart the drivers side seat control because forwards wasnt working only to find ball bearing and springs and plastic parts flying everywhere, is there an easy way to get it back together? it's killing me!
Yep AIV's If your car still has cats just drill a small hole in the pipes, if not remove them.
Q,1. Deffo AIV, If you want to keep them just drain off the water thats in em, but
why do that when you can easily remove the lot within 1hr (both sides).
Q,2. NO, there is no easy way, i gave up and bought a second hand seat, sorry cant be much of a help with that one.
