Hi guys/dolls [must be politicly correct]
Any of you lot fitted the new loom for the coil packs and injectors?
Just purchased from courtesy but cant make out how to fit them!!!!
seem to have 2 looms with 1 to many coil connectors and the injector loom has only 3 connectors and 2 bullet type connectors.
[i have come to the conclusion that they have only sent me one injector loom]
Do i cut the new connectors off the new loom and attach them to my existing loom or am i missing something here!!!!!!!!!!!!!
cheers
Dave
Dave,
I had a injector loom sent over from the states. It should come as two lots of three connectors. You have to split the looms up into individual connectors. then I'd recomend soldering the wires together and heat shrinking over the joint. Incidentley, the thick wire goes to the thin, and vice-verser!!!!!!!!!
I thought as much................i guess the same applies with the coil connectors!!
cheers
Dave
you have 2 pulsar sets, they will need to be spliced in as the 300zx connectors are all part of the main wiring loom,
:confused: Sorry Mike what are the pulsar sets!
What was sent over from courtesy were 2 looms with 5 coil connectors on them and 1 set of 3 with injector connectors on them all i thought of doing is cutting off ex conns and soldering the new ones on!!!!!!!
Dave
Dave
These are..... http://www.czp.us/Cart/description.php?II=296&Car_Type=NIS300&UID=2005042000511557.67.17.3
This is how they come, you have to order two sets. Coz at CZP is very good. I also know that DaveC (PHNW) does these aswell, I'm sure he'll be able to sort you out another set of three.
