Underdrive pulley
Just went to fit mine (again) as i got an ebay one and the belts wouldnt fit, so i got an sgp one with belts from smithy. BIG problem, the powersteering belt wont fit - its too short
Just wondered if we are doing something wrong, as this was the same with the ebay pulley we tried to fit aswell
Is there a way to get it to fit ?
Im sure its the correct part - and we have taken the PS pump off to give us more play - but it still wont fit !!!!!
Please help - as the car is in bits infront of me now
Mike
  • Replies 32
  • Views 1.5k
yea i know this mate - but i told smithy the details before he sent it - so by rights it should be ok
I hope
These are some belt sizes for a light weight underdrive pully that was bought from the US.....:-
1 x 3pk 890
1 x 4pk 980
1 x 4pk 920-930 (+/- 10mm)
A company called CPA should do these.....check for a dealer near you at:-
http://www.blueprint-adl.co.uk
On the other hand My lightweight underdrive pully from the UK off of ebay has these sizes:-
K040390 1005mm
K040365 945mm
K030350 905mm
To be honsest I havnt fitted mine yet so i dont know what ones I need for definate yet?....by the way mine is an jap import.
All I know is that the alternator/water pump UK belt is longer than the JaP or US version.
I hope these can be of some use but i dont have the definitive answer.
sounds like the pullys are different sizes depending on what one you buy.
SOZ bud
have a :duffer:
Mate your a true star - thanks ever so much
We have sorted it - dont ask
Brute force conquered all haha
Thanks again mate
Thanks again mate
Good to hear youve sorted it bud :)
Just out of curiosity.....what size belts have you got? :smash:
CheerZ
Thanks again mate
save me replying to yer PM fella, the P/S on an N/A is a 3 ribbed belt approx 35" long, numerous numbers depending upon brand are 11950-32F10 and
030350 this is also the same belt as used in the TT AFTER 1994.
See yer sorted now though. It's usually the Alt i forget to swap over between the jap and uk cars :headvswal
cheers
smithy
cheers
smithy
Smithy....can I pick your brains please...
What is the belt size then for the pre94TT import???
Here yer go, pick it out of this lot, lol
Nissan PN# '90-'93 TT: A172M-59SSAVW, '94+ TT & all NAs 11950-32F10 Power Steering
Nissan PN# A195M-97E0MVW Alternator
Nissan PN# A192M-42LSAVW A/C
OR...;
Gates PN# '90-'93 TT: 040350 '94+ TT & all NAs: 030350 Power Steering
Gates PN# 040390 Alternator
Gates PN# 040365 A/C
OR generics...
'90-'39 TT: 4 rib 35", '94+ TT & all NAs: 3 rib 35" Power Steering
4 rib 39" Alternator
4 rib 36.5" A/C
cheers
smithy
:rolleyes: Thanks smithy.....i think:rolleyes:
That must of taken you a while to compile that lot :bow:
Much Appreciated fella ;)
Any yer not sure just ask, just need to know year, jap or uk and n/a or tt and you (I) can work out all 3 of yer belts.
cheers
Fitted Lightweight pulley to my Uk Z. These are the belts I am using
Gates PN Length
Air Con 48359 925mm
Alternator 48365 1000mm
Power Steering 48356 888mm
Will check the belts tomorrow mate - but i must say (ive just got in from "testing") car goes miles better now, much better up around the 4500 rpm upward mark
Well chuffed - thanks Smithy for the bits
Put on chromed rad pipes and a few more underhood EL lights too
Absolutely awsome
Thanks again Black Magic - like i say will check belt numbers in the daylight
Mike
Do your belts squeal at all? Mine do and its getting worse. Tighten it as much as i dare and i think its too tight now.
Absolutely awsome
Mike
Never squeelled at all mate !!! Sounds like you might be too tight.
you can buy spray to go on the belts but not sure what stuff it is.
Probably dodgeing the problem putting that on anyway...must be a reason for it squealing...wrong width belts??... too loose??...or just too tight...as above
in short...
i dont know... :(
sorry bud
i'll get me coat :smw:
evenin...
did you manage to find the belt numbers out?
ive got to order mine tommorow ready for my week off next week...
Im going to Z'land....not to far to go...just out to my drive :wack:
CheerZ bud
:duffer:
evenin...
CheerZ bud
:duffer:
Hiya mate
Gates PN Length
Air Con 48359 925mm
Hiya mate
Gates PN Length
Air Con 48359 925mm
Looking at your part numbers mate, i'd say your air con one was a little too short, maybe that's why it's squeeling, what made you go for those belts in particular ? and just curious, what brand of pulley you got.
Also for yer alternator it depends if you are jap or UK spec as the UK spec uses a slightly longer alt belt and different to the numbers below.
cheers
smithy
cheers
smithy
Hi Smithy!
ok squeeling wise, if i put the heating to max (ECO mode) it squeels it head off. i went for those belts because i have a friend who owns a motor factor and i took a load of belts and tried them until they fit. took back what didnt :D
Its a UK spec car and it definately seems to be the alternator belt squeeling as I can make it squeel by turning on heating (ECO mode). The car does have air-con but it needs re-gasing as its not cold..
Whats even better is starting my Z at 6:00am in the morning and waking everyone up.. But thats a personal pleasure :D:D
Hi Smithy!
LOL.... :rofl:
Hi Smithy!
i had this turn the heating on and squeal like feck after fitting pulley noticed the belt was to loose on the alternator tightened job done,you can reach the tensioner from under the car anyhow :)
