Oh Nooooo! Quickly help needed...
Just been changing a sidelight bulb in the fog light housing, and Ive shorted the live to the chassis. its knocked all the sidelights out, and the dash illumination. Ive checked all the fuses in the fusebox in the right handside of the engine bay, and theyre all ok. headlights work fine and indicators etc.
Is there another fusebox? What have I done!?
There's another fusebox in the drivers side kick panel, down by the accellerator pedal..
Real easy access.. Ahem.. you'll see what I mean!
If you do a search for fusebox, you should find a pic with the Jap>UK translation too (if it's a Jap car that is).
Az
Cheers guys. Ive just sorted out the fuse, and partly fixed the original problem of the sidelight in the foglight housing not working. Only problem is now, is the foglight bulb is getting sidelight voltage on it, so I'll have to check the wiring tomorrow, seems as he's gone out to pick some ladie friends up. Its definately been played with before, as theres lot of snapfit crimps in the loom
cheers once again,
a sore-necked Mark! :lol:
If it aint broken....dont fix it
