just got a set of uk dials to go on me import and looking for a thread on changing them over also anything on putting the milage to match up with the milage of the car , as these dials have done alot more.
Also i take it i just remove the speedo converter from the old set and bin it ?? any help appreciated
cheers in advance
anyone ?? also anyone know what sort of difference it makes to the power steering after they are fitted ??
The only thing i will say is make sure you got the right series of clocks took mine apart only to find they where different....:cry: the connections are totally different on the back :(
So were mine, but you can swap the insides over and use the original case.
