Engine Noise
Hi All, I have asked this before, sort of, I have a noise from my TT, sounds similar to a big end just starting to go, its there when you blip the throtle to around 3+K and back. After some thinking/scratching heads etc I stripped the bottom end to check the bearings, and they are all good.
Engine is very clean inside too.
now I am stuck. ITS NOT lifters, injectors etc. I have a slight bit of piston slap, always have had, and its not that that I am talking about.
Any ideas?
Any ideas?
Mark did you check the main bearings??
Yes, all good. I have sent you a PM....the noise is about 3k rpm, low for an big end (?)
Doesnt smoke etc.
Some one on Twin Turbo Net has sugested cam belt idlers and/or adjuster? Make any sense maybe? This might be what I have read about before, cant remember.
