Triple A Pillar pods & what guages?
Thinking of adding a triple pod to the A pillar, so have a few questions:
1. Do I get the A pillar pod to replace the OEM A pillar or do I buy one that goes over the top of existing A pillar
2. Which one is the best fit and where is the best place to get one from.
3. What are the best guages to have, ie, Boost, Oil Pressure, Oil Temp, Water Temp. Bear in mind I have a series 4 TT which do not have boost guage as standard and already has oil pressure guage inside the rev counter.
I would like guages with black faces to match inside of car. Don't mind if they have chrome rings around them as I have DTA chrome rings on my existing dials.
4. Where is the best place to buy me guages. I don't want to spend hundreds on each guage, buy then again, I don't want a heap of shite neither.
5. Boost guages I have seen are either bar or PSI. Can you buy guages with both and if not, which is the best, bar or PSI.
Steve
Hi,
1. Definatly get one that replaces the OEM A Pillar. It looks a lot beter, like standard fitment.
2. Zcentre and I believe getgreddy can supply.
3. Guages - Boost, Water temp and Oil Pressure are the 3 most important. All Zeds have the Oil pressure as standard, but many replace as its not accurate.
4. getgreddy can supply. I have these, http://www.autogauge.com.tw/web/products/categorysub.asp?categorysubid=26 but find then hard to see in Bright sunlight.
5. I prefer PSI, but whichever you can read more easily I guess.
Steve,
Drop me a PM for prices on gauges and Pods :)
i suppose PSI is easier to read - its easier to say 12PSI, 14PSI etc. than 0.8bar 0.95bar blahdy-blahdy-bar.... ( :duffer: ) Either way I think triple-gauge pillars look the dogs :bow:
water temp should be the 1st gauge on the list and oil presure boost is handy to check for leaks and if your upping the power also handy to check how much boost your putting out
water,boost,oil pressure
I'd go for oil temp and water temp... If you lose either from the engine you should see the other one go up.
Definitely replace the A-piller and Oil Pressure, Boost and Water Temp for the guages.
Just be careful when you first drive the car with them in ! I spent the whole time oggling the guages instead of looking where I was going !!
Mark
:D Greddy........:bow::bow:.......:D
