Vac pipe?
I've been replacing the vacuum hoses and have found and fixed one leak (pipe under o/s TB was holed), but I'm sure I can hear a hissing from the area in the attached pic. Is the circled pipe a normal vac pipe which I can remove and replace, or are there any other vac lines below this one that might be causing the hiss?
I replaced that exact pipe on mine. I had to cut it off though, as it had gone so hard, it would not bend to get it off.
Cool - thanks mate. I'll have a go at getting it off tomorrow. :)
Woooo! Back to 9psi! :hyper: :D :dance: :nana2:
