help needed
just replaced fuel lines with smithys kit started car n runs lumpy :confused: not firing all cylinders :confused: all help appreciated
Is it misfiring? Is it one side which it is misfiring.
Put your hand over each side of the exhaust pipe. You can feel which side it is.
have took off coil connectors and reconnected cant really tell if 1 knackered? sounds like there is an air leak drivers side at the rear of engine any 1 any ideas?
You have re-connected the vac line that was previously on your metal hard line across front corner of plenum ?
smithy
Can't really seen owt there mate, too dark and too small, this link shows matts car and you can just see the vac poking out from plenum, under his strut brace and to connection at side of battery.
http://www.smithys-place.co.uk/gallery_matt.htm
and here's mine which is a bit clearer
http://www.smithys-place.co.uk/300zx_fuel_kit.htm
Don't look at Tonyc's car, his is different.
hth
smithy
why not put your z up against another z with the same ful line kit and compare,would make life easier
