i`ve lost the horn
:cry: Hi guys i have a problem with my horn it`s just not working when i press the horn the relay clicks and the fuses are all ok but i just get no sound from the horn, any ideas.
cheers Ray
sounds like an earth fault at the horn itself, they do tend to get battered by the weather, and can corrode, try cleaning the contacts up
Get a multimeter across the horn wires and see if the power is getting there. If it is then could the the contacts on the horn or the horn itself. If not then you have to start working back towards the relay.
cheers Ray
I had a similar problem once, traced it to over indulgence in alcohol :D
If the relay is clicking then it does sound like a bad earth, might be worth feeding 12V direct to the horn +12V connector. The only problem I've found with this method is that one can sh1t one's self in the process!!
cheers guys thats been a great help
