Engines Cutting Out !!
Driving home 2nite ,put my foot down about half throttle "ish" , boost started building and the engine died , imediately took my foot off and the engine ran :confused: , tried it again -boost coming on strong ,engine died , took my foot off, ran lovely .
Its running perfect under normal driving but not under boost :headvswal .
Any ideas chaps, could the ptu starting to breakdown cause this? thanx allan
Sussed it!!-It's silver! :D [had to be siad!]
If ya don't sort it you know where I am-should do,gone through 2 kettles! :wack:
Does your car have an aftermarket cone filter in it?
yes its got an apexi , it was raining if thats what you was gonna ask but only lightly been in much heavier without a problem . Drove home tonight it seemed ok , manta v8 suggested it might be the afm on its way out.
Wondered if anybody has had the same happen?
Yes two kettles full of WATER , tight git :tongue: :tongue:
No I was going to say that its the old cone filter vortex problem. But the funnel shape of the apexi filter stops that from happening.
It could be the PTU or the MAS. Run an ECU diag. Also clean the connections on both of the units.
Cheers i,ll give that a go. :D
