Aircon pump replacement Q's
As summer is slowly approaching, I need to sort out my Aircon.
Aircon works perfectly fine when I turn it on, except for a loud deep whirring noise from engine bay, that changes note with engine RPM. So I just use it in 'eco' mode, which makes no noise.
I would guess its the Aircon pump bearings or something like that ?
If replacing the Pump...would the system then need to be regassed ?
That whirring will be the magnet clutch on your aircon pump.
To confirm you can test with Conzult if you know anyone with one?
