protoj · Tuesday at 18:48 1 day
Hiya All,
I've just uploaded some pic's of my Z before and during restoration. Just thought you might like to see them, they were certainly eye opening for me when I first saw them, check out the bonnet picture, it had 28, yes 28 dint in the bloody thing. Should have bought a new bonnet!!
Regards
John
