ALC Help Required
Have just installed the HKS ALC unit and have a prob, The car wont go into top gear and overdrive (yes the overdrive switch is on), have checked everything that i can think of, and checked over and over again the connections, but i cant see nothing wrong?
Also when you come off the gas the revs drop down to tickover RPM, even doing 70MPH.?
Has anyone else fitted one of these and had the same problem? :smash:
HELP
check you havent over tightened the screw it only needs to be hand tight.
ย
ย
Had same probs couple years back,screw into main block conector too tight,forces conector ends away from main block,think i left it at 1.5 turns with spaner when taking up the slack so to speak.
ย
Tony :)
Ok, so if i have screwed to hard :-) and pushed the femal side of the connector back, how can i close the connector to make them come in contact with each other ?
ย
Undo connector and retighten ... this time making sure you don't over do it.
