help to identify a sensor
hi guys can anyone tell me what this sensor is on my zed (see photo) i have one of these each side both with a vacuum pipe disconected do these need to be connected? cheers for the help kev
mate thats a crap pic
not got a clue gregg there are 2 of them one each side both got 2 electrical connections one vacuum pipe connects to the balance bar the other 2 shoot off down by the side of the engine somwhere my mate has a j spec that has one of these fitted but not 2 like mine
just to add to identify this sensor i've just been out in zed with it connected and disconected the turbo boost pressure is a lot higher at lower revs with this sensor disconected, any ideas what it is anyone?
Could be solenoid valves for a boost controller??-maybe removed controller and left these on! :confused:
could be so another question where would the vacuum pipe connect to usually the pipe connects to the rear left of the engine by the balance bar
That is a boost solenoid called an Amal valve they were used by Ford on Sierra and Escort Cosworths, the ports were designed to take diiferent size ferrals, this gives a base boost level, activating the valve opens the next port which "bleeds" an amount of air off the actuator (depndant on what size ferral fitted) and that gives more boost level.
Looks like someone has adapted this to your zed as a variable boost device ( high , low ) there is most likely a switch somewhere in the cabin area, incidently on the Cosworth this device was not used as a manual boost increase system it was to reduce boost during warm up it has been reversed in your case.
Neat trick to use it on a zed.
Jeff TT
hail greg i've just traced the wires connected to those damn sensors and they are wired to the alarm god knows what they do and after much searching around the vacuum pipe was disconected from from one of the air intake pipes got full turbo pressure now and better running cheers for the help guys
