The car has started making a creaking noise when breaking or turning - especially when doing both (breaking AND turning)
Thing is, the car runs straight, breaks straight and feels like it is cornering/handling correctly other than that.
However, it also rattles like hell when going over bumps (of which there are many round here!!!) as if there is something loose underneath - sounds like the noise a train makes when trundling over joins in the track :rolleyes: .
When it was in for the clutch replacement, the garage noticed and fixed a split heatshield, but that hasn't cured the noise.
The car is running on 19s and has eibach springs/koni shockers, so I am not expecting the smoothest ride, but it feels like I am driving an old banger at the moment!! :confused: Is anyone else running that configuration and could they poss. comment as to whether there ride sounds as rough as mine??
Anyone got any suggestions/ideas??
Rich
Rich
leaky shock?legrath has a creaking noise at the mo,been diagnosed with leaky front shock
mine was the upper arm bushes creaking, so i got rid & fitted adjustable arms with bearings instead :cool:
I had this, was a loose bonnet bolt :D, had it another time too, that was a connector rubbing under the bonnet ;)
lol fingers crossed Mike!!
Paul - I had the adjustables fitted not long ago, but I wonder if something in that area has come loose!?
Before the noise got a creaking, it sounded like a knocking particularly noticeable as the car rocked to a stop under breaking - thought that my brakes were loose or someting!
I'll get someone to check it out - after I've checked for loose things rubbing the bonnet lol.
So far it could be
Shocks,
Upper Arm Bushes,
Bonnet Bolts,
Tension rods>
Its an idea to say we dont know LOL ;)
I had something like this and it turned out to be lower arm from the crossmember to the wheel hub.
So there you go, it could now be any one of 5 things.
