Suggestions on Weight Saving
Evening bodders.... :duffer:
I have started a mission to loose as much weight on me Z as possible.
All within reason as its not a race car :cry:
I need to keep the rear seats(luckily there only foamy sh#t)
The rear spoiler must weigh some but it needs to stay.
I know some items like c/f bonnet for std Z bonnet is not alota difference but it all adds up :dance:
of course most of this is eliminated as soon as i put any GoGo juice in and i cant get any thinner than i am already but it all helps.
Please add ideas to the list to help me on my way...Chunk has already contributed(CheerZ :cool: ) so i have included these:-
Remove :-
speakers
Headunit
Cruise control
AIV's
HICAS (complete removel)
Rear Wiper + motor
weights in boot lid
Boards & carpet in boot
Foot mats
Fit/Change:-
Pully set
Lightweight Flywheel
Electric seat out...non-electric seat in
Sub conversion (removes large rear boot glass window with tiny piece)
Carbon Fibre bonnet
Foot well Wooden boards with Alloy replicas
  • Replies 42
  • Views 3.3k
single exit exhaust?
Air con gubbins?
Spare wheel (carry tin of stuff)?
The nut behind the steering wheel :wack:
Climate control system?
Replace targas with carbon fibre panels??
Lighter wheels?
is it auto? if so convert, save loadsa kilos!!!
lighter rad? ally?
Stage I
Cargo Cover………………………………........ ......................... ...........5
Spare Tire, Jack, Wheel Chock’s, and Inflator Can…………………..…32
Rear Hatch Weight………………………………....... ......................... ..3
Driver Seat (61)àAftermarket w/ alum. sliders and bracket(25)…….…36
Passenger Seat (42)àAftermarket w/ alum. sliders and brackets(25).….17
Rear Tow Hooks………………………………........ ......................... .......3.5
PRVR System………………………………....... ......................... ............1.5
Center Support Bearing………………………………...……. ...…......….1
Stock Drive shaft (31)à 1 Piece Steel(17)…………..…….….….... .……14
Battery (45-50)à Light Weight Battery(15)……………………………..3 0-35
*(Also move to trunk, pass. Side)
Pre Cats (21)à Down pipes (14)…………………………….…..…..... ....7
Stock Cats(26)à Test Pipes Alum(14) SS w/ flex joints(17.5)…………..8.5-12
Flywheel(21)à RPS (12.5)……………………………........ .....................8.5
Under drive Pulley(11)à Lightweight Pulley(2)…………………………..9
Headlight Aimers………………………………....... ......................... .........2
Timing Belt Covers………………………………....... ......................... ......1.5
Fan Shroud………………………………....... ......................... ..................1
Apparently the Stock Air Box Weighs More Than an Intake………….…..5
……….TOTAL…185.5-194
Stage II
Window Washer Reservoir and all Associated Lines………………5
Cruise Control………………………………...... ......................... ...2
All 4 Strut Actuators (do you really use them?)……………………1.5
Black Tar Sound Deadening Material………………………………33
Rear Wipers………………………………....... ......................... ......3
AIV System………………………………....... ......................... ......10 ???
T-Tops (14.5)à Carbon Fiber(5)…..X2.…………………………. .15
T-Top Wind Blockers………………………………..... ..................1
T-Top Shades………………………………....... ......................... ...2
Fog Light Air Ducts……………………………..…...... .................2 ???
Light Weight Steering Wheel………………………………........ ...5 ???
TOTAL…79.5
Stage III
Front Carpet w/ Insulation Attached………………………………15
Rear Rug and Wooden Spare Cover……………………………….8
ALL Plastic Panels with their Insulation Attached………………..23
All Tweed and Carpet Covered Panels……………………………10
*With exception to those touching the Dash
*Also Doors are intact minus the AC ducting and Insulation
Misc. Insulation………………………………... ......................... ...5
Radio, Speakers and all Associated Wiring………………………..30
Antenna and all Associated Wiring……………………………….2.5
Rear Pressure Equalizing Vents……………………………….......1 .5
TOTAL…95
Stage IV
AC and Heater System in Car (located under dash)………………26.5
AC Condenser and Other Engine Bay Lines (in front of radiator)..10
AC Fan……………………………….......... ......................... .........5
The Idler Puller and belt for the AC….………………….............. .13oz (round up to 1)
Air Bag Controls in Car and all Associated Lines…………………6.5
Front Wipers………………………………....... ......................... ....5
EGR System………………………………....... ......................... .....5 ???
Carbon Canister………………………………..... ......................... .3 ???
TOTAL…62
Stage V
HICAS Removal and NA Power Steering System Install………….37.5
HICAS Eliminator weighs 2lbs
Remove Passenger Seat………………………………......... ...........15-20
All wires no longer in use if following Stages I-IV…………..……20
TOTAL…72.5-77.5
GRAND TOTAL….494.5-508 lbs
Stage VI
Escort FPR Doors (2+0Only)...……………………..... ...................50 ???
*(They only weigh 10 lbs a piece)
Speed Glass install for all Glass would probably drop……………..50-75 ???
TT Rear to NA Rear is supposed to drop a good……………………50 ???
Dash, Gauge Cluster Cover, Metal Bracket, and Din Panel…..........16
Door Skins………………………………........ ......................... ........10 ???
Your Soggy Ass Turbo Deck (I would never ditch mine)…………..10 ???
Carbon Fiber Hatch with Lexan from AMZ…………………………40 ???
Titanium Exhaust………………………………...... ......................... 15 ???
Install Lighter Fuel Cell………………………………......... .............???????????? ????????
Cut out sheet metal skin on rear hatch……………………………….??????? ????????/????
TOTAL…252-267
SUPER GRAND TOTAL…746.5-775 lbs
Air con gubbins?
Now why didnt i think of that :headvswal
Ta ;)
:shock: Chris :slap: on the back mate:D must of taken ages to write all that.....:duffer:
Blimey....
Excellent list chris....
Thanks....Copy....Paste...Save....
:bow: :bow: :bow:
Light Weight battery is 1 hell of a mod and is something i'll be offering very soon, weight savings are massive ;)
Will that be these then? :confused: :-
Carbon Fiber Hatch with Lexan from AMZ(courtsy of chris's list)
Definately wheels as my AMG lookalikes look like they aint light....want the Hockenheim styleeeeeeeeeeeee.
The CF hatch is a no goer ATM unfortunetly :(
Sounds a shocking idea chris.
Definately charge me for one of those.
I would be terminaly gratefull.
Dont wanna sound negative or short with you but how long till u get them...are you positive you can get them?
Sorry....been at me christmas crackers again...
Or was it that CiDeR and JD. :confused:
But seriously.....Contact me when you get them :D
CheerZ chris :bow:
CheerZ chris :bow:
You been on the shandy again :D Shocking behaviour :nelson: :rofl:
EH??? :confused:
Does that mean cant get any at all or does it mean for Automatic Transmission only???
Me is Fick :smw:
EH??? :confused:
Me is Fick :smw:
Just a non starter :(
What the fook....
Didnt know me Z had airbag???
U pullin me leg chris?
UK
USA
Later J Specs had fun bags
I was told "the nut behind the steering wheel is the most dangerous thing in a car".
I located and removed mine with a spanner and feel much safer now.
Didn't save much weight though.
UK
USA
i got early 90 jap import...so i aint got diddley then? :cry:
No but think of the weight your saving ;) :nana2:
FPMSL :rofl: :rofl: :rofl:
U ON THE JUICE 2?
U ON THE JUICE 2?
:duffer: :duffer: :duffer:
Yes
:dance: :dance: :dance:
yeh dont worry about your life aslong as you save 6lbs LMAO :rofl:
Greg Limbs can be sewn back on ffs :slap: :smash: :rofl: :rofl: :rofl:
jesus chris - have you considered counseling ? you need to get out more
:smash: :smash:
Regards,
alex
:smash: :smash:
Regards,
alex
Who be that then? :confused:
