I am thinking of putting some extra gauges in the slot below the stereo. Was gonna put water temp, oil pressure and turbo boost after reading all the posts regarding the inaccuracy of the standard gauges.
ย
I have found the centre console gauge fascia from the zcentre, but can anyone suggest what sort/make of gauges to go for? :confused:
You want top of the range or a budget brand ?
are the budget ones any good? If they are then they will be fine.
ย
I have water temp, boost and oil pressure.
ย
They are very handy to have.
ย
They are good prices too Chris. I already have my dials though ;)
Thanks Chris, they look well smart!
ย
Do they light up at night when you put your lights on?
Yup they sure do :)
How difficult are they to connect up? I already have an aftermarket boost gauge (installed by the previous owner) so i guess the new boost gauge would just connect to that.
ย
Could i have the new oil pressure and water temperature gauges working at the same time as the ones in the dash? Or do the dash ones get disconnected when the new gauges are installed?
Boost you would be able to use the plumbing already there
ย
Other ones should be the same.
