Switch pack LED's
Right then guy's. Those of youwho have changed your switch pack (the ones around the instruments) to LED's - have you got any of the actual LED that you used? Are they the bulb holder type or the LED with the 2 wires hanging off that need soldering in?
Thanks in advance
Ivan
Thanks in advance
Ivan
Try http://www.ultimateleds They will help you.
I bought some and put them in the origional holders
Markz
Thanks in advance
Ivan
I am sorry it is http://www.ultraleds
Markz
they are the 2 wire ones mate, i have done mine.
I've just uploaded a new version of the document with a solution to the demister problem. If you downloaded earlier, you might want to get the new one ;)
I bought some that should have been direct replacements but they didnt fit, so I just yanked the LED and resistor out of the holder and soldered the frickers in place!! :D
Hmmm need to get some. Markz, which ones are they on that site - I've used them before for some for the front but weren't as bright as the standard bulbs and I like to be seen! ;)
Ivan
Ivan
Wich onees are you replacing?
Markz
Markz
All the pod back lighting and the orange ones in the switches,also the dash back lights
Markz
