How to remove ignition barrel?
is this possible? i had a go this weekend and it looks permenantly fixed, if it can be done then how?
yaseen
yaseen
Yasseen these are put on with snap bolts which as the name suggests the head snaps off them when they are in place so they can not be removed , the only way is with an angle grinder or dremel etc or if you think you need some exercise hammer and chisel, after that there pretty much rendered useless
Ryan
Park it up in Liverpool for 20 mins, soon be off !
Ryan
if your clever like me,theres a simpler way and the bolts can be re-used
drill a small hole through the centre of the sheer bolt approx 3mm tap a torx bit used for a screwdriver or cordless drill with a hammer turn with scredriver or grips and hey presto out comes sheer bolt re-use the same way HTH
if i remember correctly you can't get a drill to the bolt due to the tight space
flexible drive-shaft :p
so if i changed the locks from one car to another i would have to have two keys? one for the doors and one for the ignition? how stupid is that
I have 2 keys, one proper 300ZX one for the ignition, doesn't work on anything else, the other one is a nissan one, works on the drivers door and nothing else, nice!
unless you remove barrels from doors and get them re-keyed to new ignition key,i have a nissan wafer keying kit,being a locksmith ;)
Youre soooooo clever!
And pretty too :D
