hi converting to manual here are the parts i have so far 11lb segmented flywheel,rps clutch, braided clutchline, gearbox, propshaft, clutch pedal slave cylinder, master,pump plus oil lines (do these circulate the oil or does it run to a cooler) is there any other parts i need will auto crossmember fit manual box :D
Aha, r you the guy that bought the box of Hanksy?
ย
If so, you should have everything you need...
ย
I believe this originally was Leigh's box.... :)
ย
ย
thats me
dont know if i have everything borrowing a ramp at a friends garage dont want it stuck on there these are the only parts i have :smash:
I have posted a thread before requesting the full list of parts, do a search and thou shall find the answer! ;)
cheers guys
