Wiring sound ARGH wot a nightmare
:headvswal k i've taken apart everything, and i mean everything on the passenger side of the car to find this hole through the bulkhead WHICH i CANNOT still find :headvswal N when i mean everything i mean panels wise, im trying to run the cable from the amp to the battery through the wing, n nope no luck at all. If ANYONE has a picture of where it is you will be my saviour!
of its an auto then there will be a hole where the clutch pedal normally is. or is it a manual
its may have had a plate put over it but its easy to remove with a screwdriver. I know its the other side of the car but its easier than drilling a new hole.
I got an auto, im doing it through the passenger side if i do it by the pedals its gona be a nightmare on the otherside by the engine :(
Dodge - firstly - bad boy for not being subscribed!! (can't PM you). Send me a mail with your number vij@dsl.pipex.com and I'll call you :)
Vijay
Jus mailed u Vijay :)
why not just run it through the bonnet release cable hole ?. Do it from the inside. I've got Boost gauge pipe and Amp wire running through that. You dont need to remove anything to get to it.
their is a hole in the passenger side wing mate , then u can connect from battery through hole in wing then back into the car , alot lot easier mate !! i done it already with real thick power cable!!
I know theres a hole there but i cant find it, if sum1 has a picture showing it, it wud REALLY help.
open ur passenger side door mate , look through the gap if creates when about halfway open, where u can see inside the wing then u should see it mate. about 6 inches from top of wing and about halfway along wing , from what i remeber ( might be out abit)
Errrr put hair round it :nelson: thats all im saying
courtesy of MTL, this is the battery tray
its the 3 wires disapearing through the hole that you wanna go with
Mike you've lost your Battery.... :rofl: :rofl:
its one of them new invisible batteries they are sellin on ebay !!
Cheers for the pic Mike, n the help guys. Vijay woz a great help as well, i ran it through the wing like in the pic now im jus trying to get it from the door side into the inside of the car, so nearly dun :)
