abs
abs dash light stays on, any ideas as to why? :cry:
Can be a stuffed wheel sensor or connection to one. There is a ABS diagnostic check in the manual so as to identify what is wrong. Look it up and try it.
thank you for your reply, i will get straight on the case to see if i can suss it out, thank you again
  • 1 year later...
i had same problem abs on all the time i changed my abs control unit it then did not come on stright away however when i drive over the test speed it come on check the number of flashes and its five which is front left wheel sensor so will replace will let you know out come when it is done ...good luck hope you sort it m8
