hicas question
if the hicas is removed say to fit hicas eliminator bar what do you do with the two pipes that go in to it? amthinkingbout getting 1. is the installation easy?
cheers
cheers
AFAIK you can return them in the engine bay, or fit NA Hydraulic pump... and free up some space!
Rich
how is this done any links anywhere? cheers
Easiest way is to just remove the HICAS unit in the engine bay. Blank off the feed from the power steering pot and the HICAS return to the power steeing pump.
I''ve got a SE HICAS Eliminator bar if you want to buy one. Never been used.
