manual gearbox conversion
when doing the conversion which is the best option, cutting the auto harness off the autobox and joining or just bridging the inhibitor wire under the bonnet and extending the other wires
does also does it need to use the neutral switch on the manual box?
Richard
Call Jeff @ Z-edworld, he offered to talk me through the installation....
I would love to help but I aint got a scooby....thank god! ;)
Keep the auto harness. Phill at C&S woulds will talk you through it. I didn't thinking using the manual harness would be stait forward. I still have no speedo or reverse lights yet and am going to re install the Auto harness and convert over. Luke at the Z centre will tell you about this problem as well.
mark, i've tested the circuit out, and the reverse is a green wire and all you need is a power to it via the switch, as for the speedo, it doesn't affect the harness on the auto, just straight plug in, I've tested it and it works fine, just wasn't sure if the ecu needed any other inputs
Richard
