runing problems
Hi
hope someone can help or give a little advice, I'm having some running problems with my VG30E i'll try and discribe them
it won't really idle and wont rev with out stalling, you can however if your carefull get the rev up slowly to a point then it pulses the rpm (kind of like what a rev limiter would do)
I ran the diag on the ecu and came up with these details
red green
1 2 airflow meter
1 3 Cylinder head temperature sensor
2 1 Ignition Signal
2 3 Idle Switch
3 1 Air conditioner
4 1 Check fuel temperature circuit
Any idea's advice is greatfull
thanks
I think it may be better to reset the ECU and make sure. Some of those codes could be old.
the battery has been off for days, thought that would have cleared the codes?
Yes it would have done :(
Oh :headvswal
Any idea's then? where i should start, i can't see them all being worng (i hope)
it's still factory mate nothing changed
fogot to put in last post,
just found a fsm for it so i can test the sensors and wiring now :)
I'd look into the AFM error code first, as that would introduce a rev lmit at around 2.5k rpm if there's problems.
Check the Coneection is secure to the MAF, and check the voltage.
cool i have another afm but it's of a 300C still vg30e) might try that on it and see if it makes a difference i know it may run a little lean with it but i hope it will be ok just to test
the maf don't look to great tbh
thanks for the point's somewhere to start now :)
