unwanted drift
back end ov my car is all over the place would any body know where would be the first thing to check
much appriciated
mot
Assuming you've already checked the tyres themselves (wear and inflation) check the rear shocks. I bought mine knowing they'd need doing- whenever you went over a bump the back end would squirm around. Been superbly behaved ever since I replaced them (lead right-foot aside :D )
Other things- your HICAS warning light stays off does it? May also be worth getting 4-wheel tracking too.
Mark
cheers yeah it jumps when accl and hitting a bump ,very scary
hicas light stays off
mot
Amen definitely do the shocks! Replaced all four on mine and couldn't believe the difference. The rear used to track every tramline and bump in the road - felt like someone had loosened the rear toe link it was that bad...
sounds very familier
new ones orderd
mot
I had that problem and now I have had the worn hicas rods replaced it is much better.
Both.
My hicas was fooked so I stuck a remover in. Was a lot better, but now its obvious that 15 years wears out the other bits too.
best to jack the car up and grab the wheel and give it a realy firm tug back and forth. If you have any movement it will 10 fold when moving.
There should be none. whatsoever.
yep same here guys,
jack the rear of the car up and grab the wheel and try to pull it in and out if there in any play at all hicas arms are worn out!!
i have the same problem .........anybody recommend the best shocks to replace them with or is keeping standard the way to go
36psi a bit high methinks......this from a man who knows FA. I run 30
cheers guys whish id have been here for advice a few mounths ago when i was charged £600 for a machanic to change a plug!!!!!!!!!!!
ive had it on the ramp and theres a tiny bit ov play in the rear end[track rods]
so two ov them have been ordered now
thanks
tom
