Car seems to jerk to one side
Got the new car and its great BUT every now and againit seems to jolt to the left when going over a rough bit of road, only ever does it o left. hecked tyres etc and they are kool.
any ideas why its doing it, bushers, hicas ??? :bow:
Got to be worth check the rear track rod ends, before checking anything else.
Shockers?
lower arms
tension rods
Rack
Wheel bearing
and loads more :mad:
i got same.
so going to replace everything. bet its just the larger tyres.
might be worth checking the rear subframe bushes too - make sure they havent burst
i have the same thing especially over cats eyes and white lines very un nerving
is it anything to do with the hicas??
I had the same prob, I put new hicas arms on and that sorted it!!
Rich
Put a porn mag on the right hand side of the car to even up the jerking
:rofl: :rofl: :hyper: :D :nelson: :nono: :rofl: :rofl:
My car was skittish over bumps and the Hicas rods were replaced and problem cured. jack it up and see if you can turn the wheels on the rear as though steering to see if there is any play.
almost certainly rear hicas arms. i had exactly the same problem which was fixed when the arms were replaced. about £250 all in i think.
are they hard to replace yourself ?
TBH im not really that mechanically-minded but i would imagine it would involve jacking the rear of the car up for a starter. dont know how far into the suspension you'd have to go. hope someone else can help more
They are quite easy to change and are 65 quid each from nissan. You will have to have a 4 wheel alignment check done afterwards tho.
cheerz, mickey
