door open light help
the door open light on my z32 has come on and wont go out. checked all door are shut and checked connections on door so leaves the boot. Where is the boot open or closed sensor that will control the light going on or off , have a feeling when i had the concept alarm fitted they may have donw something. So anyone help?
The system works on earthing out the door switch remove the swiches and check for a bare or crimped cable. does the interior light stay on?
Markz
i bet your boot isnt closing properly, if you remove the centre panel inside the boot, youll see 3 bolts holding the latch on, my bet is these have come loose or the latch has got knocked down a bit, try undoing the nuts asnd sliding the latch up or down see if that cures it.
