My 300 has the Race logic Traction Control setup, a friend has had a laptop on it and confirmed that it is correctly set up for the car, but thinks it is not getting the correct RPM feed from the ECU. Hence it doesn't actually cut at the right time. My question is does anyone have the correct pins outs that I need, or any advice on what I can try?
also make sure the wheels are correctly assigned to front or rear
Also make sure the TC is setup for 6 cylinders.
Do you have the right software installed?
