headlight / cruise control problems
can any one help i have a uk spec zx when i bought it the passenger side headlight dip beam was wired into the drivers side so i decided to connect it back up and hey presto dim dip worked but the passenger side headlight sometimes works ok and others it won't work however dim dip always works with no prob so is the problem my dim dip unit or the main light switch? also where is the dim dip unit located?
now to my second problem my cruise control won't work it turns on but thats about all it won't set to a speed, when i was poking around under the bonnet the other day i found to round sensors one on each side which take 3 vacuum pipes and have 2 wires plugged into the top on each both have had a vacuum pipe disconected are these to do with the cruise control if anyone has any ideas why it's not working or what the sensors are let me know cheers guys & gals. :headvswal
Dont know about the first question mate but when the cruise didn't work on mine it was the brake and clutch switches that needed adjustment. This is a bit of a job as they are behind the dials I think so it's either dials out or reach up from the floor and do it that way.
Ivan
cheers for the help on that ivan i tested the theory about pedal sensors and lifted the cluthch pedal slightly whils driving then tried cruise control and it works looks like i got that to do this weekend that'll be fun just the mot to go in 2 weeks
so the other question remains can anybody tell me where the bloody dim dip unit is on a uk spec z?
Where your dip unit is?
My passenger main beam didnt work once. It was just the connection to the bulb. Just press it in a little see if that makes any difference.
have tried that and all the connections in that area only 3 things i can put it down to the light switch,relay or dodgy connection on dim dip unit(as dim dip always works but full dip beam does not)
