Grin, Grin, Grin
After picking my new Zed up on friday, i have spent 3 days going over it with a fine tooth comb (cant use it on me head ? nothing to comb), and have a few questions for you good looking, very inteligent peeps on this wonderfull forum.
Hope that was sufficent cos i ain't ass licking anymore.
I bought the car knowing i had to replace the center prop bearing, but the more i drive the car the less it seems to vibrate??? i know the car has been standing for some time (18months in a garage in japan) then it came to the uk last october, and the guy that had it also didnt use it, he has only just registerd it (1st jan 05). so i am going to leave it a while before i do anything to the prop.
next question :- With the engine ticking over there is a gurgling noise coming from the drivers side, at the back of the engine bay near the A pillar, and when i disconnect the vacume pipe it stops on that side. it seems to be comming from under the top of the wing????? any ideas?
Next question :- when you replace the cats with the complete front system each side is there anything that has to be done to the ECU, or anything else???? :bow:
Sorry about all these questions but if you dont ask you will never know anything, not that i do anyway :wack:
Thanks in advance peeps
the gurgling is the aiv valves to a search to find out how to fix it, its real easy.
If it is the centre prop bearing that the problem then it usually gets better as it warms up, but not always.
Nothing else to do when removing the cats.
I noticed that there is a small pipe that Tee's off the exhaust, what do you do with that pipes?
Wot do you mean leave it ???, just leave it dangling or cut it off, or remove it??
did that 3 years ago and no hassle since
That was an exellent link :bow: to the person that wrote it, and thanks for the link, remind me to buy you a beer at the meet on the 13feb if you is a cumming :dance:
