Have just completed a cambelt change on the Z for the first time. Bought the kit from Courtesy including new tensioner, pulleys etc. I followed the tensioning instruction according to the TTnet procedure. I.e. 4mm gap on tensioner after 2 rotations. Now I assume the preload on the tensioner is correct and checked by Nissan? Is there a more precise way of checking the actual belt tension?
Once reassembled the engine now seems to produce a slight whirling sound which suggest to me maybe the belt is too tight, I have eliminated all auxiliaries and fan. Car has done 100 miles since belt change. If this whirling sound is a common thing that goes away after a little running, I’m not too concerned. I don’t want to completely strip down the front end to check the tension if there is no need to. Cheers
Andy
No posts to show
