FAO PaulC
Paul my Z is going in for MOT tomorrow do you think it will pass on emissions? Or will I have to bribe him LMAO :wack:
cant see why not mate - as iv said before, the zed is only subject to a non cat test, so unless its running too rich then there should be no probs.
ย
if its rough at idle it may have excess HC's, but as long as the CO is within the correct levels then you can retest the HC's at a faster engine speed IIRC.
ย
ps - how does it drive???
yeah, here it is:
ย
If a vehicle meets the CO requirement at its normal idling speed but fails the HC check, re-check the HC level at a high idle speed of 2000rpm. If the HC reading is 1200 ppm or less, the vehicle will meet both the CO and HC requirements.
. the CO requirement must be met with the engine running at its normal (low) idling speed
. do not use a cold start/cold running mechanism to achieve a high idle speed. Instead, apply light pressure to the throttle pedal.
ย
thats the only part you might get caught out on if the tester isnt aware of it :)
ย
its not uncommon to pass the CO test, but fail the HC test with tuned engines with lumpy cams etc that dont idle too well
All sorted,she passed without a issue:D,Peter took her out and done 90 miles last night and she is running sweet as a nut :bow: :bow: :bow:
so the micra transplant went OK then
:mac1: :tongue:
ย
we told you before Roy - stop talking about your operation on here. :x:
My local ex Nissan dealer who does my MOT does not even bother doing the emissions test,once said to me"Its not in the book,wont bother with that" :cool:
ย
Tony :D
ย
Tony :D
ย
:eek: should still have a test & should pass it no probs!
