hicas
just had back end jacked up. had a look under at hicas while some1 wobbled wheel from side to side and could see an feel play in both the arms that come out off main hicas body. I take that this is what is causing my rear end wobble lol :confused:
thats right mate. i had the same problem - handling was a nightmare as the car skipped a lot from the back end - nearly lost it and put the car into a bank (the soil kind!) im not sure if they can be fixed or if they have to be replaced. anyone?
cheers mate done alot of asking bout this on here an finely cracked it am just going to replace them think there around £50 each of trader on here
There are the arms which also have the inner ball joint parts in the rack and then there are the outer bushes that press into the hub carrier parts. Find out which ones are worn.
