Yellow warning light
Help. Came on last night, it's the light above the ABS warning light looks like a windscreen with a jet of water, checked the washer bottle and thats OK.
Any ideas please
yea that should be your washer fluid light, you may have a sticky float sensor
yep thats your washer bottle warning light. if you've filled the bottle it could be a loose or bad conector. you can get to bottle by removing wheel splash guard to check conector
