N/A to Tubby conversion
I was just wondering if anyone knew where i could source a second hand or new bolt on turbo conversion for my NA Zed. Ive been looking at Jim Wolfe Tech Sports 650 (JWT) turbos or greddy TD05-16G, but ideally i want a kit that has everything i need for the job - all piping etc
And before you say it - no i should sell and buy a tubby. Mine is mint i know the car and its already tuned to capacity for an NA - so i dont want to start again !
Has anyone done the conversion before ? If so could they tell me all i need for the job - injectors, ECU etc
Any help would be greatly appreciated - and if ive got to remove the engine then i will port and polish, and get some JUN adjustable cam gears too - but if its going to cost 10 grand then i wont bother
Thanks for any help peeps
topless converted his NA convertible to TT, you may be better off finding a good TT engine and doing the swap that way.. plus you'd be able to recoup some of the costs by selling your NA engine afterwards
Thanks guys - will check out that link now Vijay
Deffo speak to Mark (Topless) not as easy as bolting the tubs onto a NA engine :(
if you want to bolt tubs onto your NA engine, then check out this link:
http://www.z1motorsports.com/PDFs/NAwTTs(partsprices).pdf
bear in mind that unless youre lowering the compression ratio, you will only be able to run very low boost pressures, no point in going bigger than stock. (& i wouldnt wanna do this anyway TBH!!)
good luck!
You could always bolt a centrifugal blower onto it, maybe 6psi with stock compression, or more with intercooling.
i may try and super charge it - if i can find a suitable place for the charger - which doesnt look too easy. I can get superchargers very cheap though - so it might be an idea.
Thanks for all your help - im currently looking into this with a view its probably too expensive. Nevermind - i am happy with the performance ive already got, but its always nice to get MORE POWER
If its any help, here is some spec from an NA in the US.
ENGINE
Non Turbo Block Honed 0.20 over, Ported/Polished Twin Turbo Heads
Ported/Polished Twin Turbo Intake Manifolds
Eagle H Beam Rods
JE 11:1 Pistons
Toga Main and Rod Bearings
38mm Stainless Steel Valves
Amazon Racing Regrounded Camshafts
Stillen Headers
Ported Throttle Bodies
Injen Intake System
Complete Headers-back 2.5" Exhaust
Specialty-Z Test Pipes
NGK Spark Plugs
KOYO Aluminum Radiator
Unorthodox Racing Lightened Crank/Accessory Pulley Set
Stillen Oil Cooler Kit
POWERTRAIN/TRANSMISSION
Converted Automatic to Manual
JDM Twin Turbo 5-Speed
Centerforce II Twin Turbo Clutch
Stillen Lightened Flywheel
Z1 Motorsports One-Piece Driveshaft
C-Tune Short Shifter and Shift Knob
That has 306 rwhp @ 7200rpm
Might give you a few ideas of how to get more power without turbos.
I just got a price for Jim Wolfe cams - 1000 dolla plus postage and tax mmmmmmmmmm
Nice lol
Thanks for that list mate, much appreciated
It ain't worth the time and the agro unless your model ain't available in Turbo guise :D
if you want give me a ring about it, it is a very complicated project!
& takes about 3 years to complete!! :rofl:
