protoj ·
http://300zx.co.uk/200sx/ubb/Forum1/HTML/002180.html
Would you guys be up for this? 200's V MKIII Supras and 300's V MKIV Supras.
We are thinking of hiring bruntingthorpe or something similar? 0-60's 0-100's 1/4 mile and prehaps top speed runs.
Any takers?
